Slotted headstock in 10 minutes
http://www-.luthiersforum.com/forum/viewtopic.php?f=10117&t=34348
Author:  Pete Howlett [ Thu Nov 24, 2011 12:10 am ]
Post subject:  Slotted headstock in 10 minutes
I get asked regularly about this type of headstock on another forum. here's my video on how to execute the slot cutting. Ramping and drilling takes the whole time fram up to 30 minutes with close on 8 minutes of that being very fine hand sanding...
Author:  Don Williams [ Thu Nov 24, 2011 9:27 am ]
Post subject:  Re: Slotted headstock in 10 minutes
Simple, works great. I like it.
Author:  LarryH [ Tue Feb 12, 2013 8:41 pm ]
Just built one of these for my slot head design - WORKED ABSOLUTELY BRILLIANTLY!! What a great design and idea. Took me 3 -4 hours without the jig - 5 minutes with the jig. Again, brilliant!!
Author:  Alain Moisan [ Tue Feb 12, 2013 9:25 pm ]
That's brillant!
Author:  LarryH [ Tue Feb 12, 2013 10:06 pm ]
It took a bit to get it just right with the router pattern offset but once complete it works great. Now I can choose almost any slot head design and have them finished in minutes instead of hours. Sweet, and thanks again to Pete for posting this.
Author:  MaxBishop [ Wed Feb 13, 2013 6:35 am ]
Pete,
Many thanks for sharing your jig design. It will save me many tedious hours.
Max
Author:  charliewood [ Tue May 27, 2014 4:56 pm ]
the video s gone - bummer!
cheers
charliewood
Author:  WendyW [ Wed May 28, 2014 10:56 am ]
What happened to the video!!!???
Author:  sdsollod [ Wed May 28, 2014 1:19 pm ]
I want to see the video too, but it's not there...
Author:  Beth Mayer [ Sat May 31, 2014 10:08 pm ]
Pete removed all of his tutorial videos. I think he's either selling them now or offering classes.
Author:  Pmaj7 [ Sat May 31, 2014 11:54 pm ]
Yeah, what a bummer. I wanted to try that one too. Looks like he is offering classes now. I guess, no more milking the cow for free!
Author:  charliewood [ Tue Jun 17, 2014 11:02 am ]
Mabye one of the people who have already seen it .. and preferably built the jig, could illuminate us darkened fumblers...????
Please? Please? Pleeeeeeeaaaase? (obvious Kramer reference there) :)
cheers
charliewired
Author:  Dan Pennington [ Wed Jun 18, 2014 8:15 am ]
I saw Howlett's video a couple of years ago and this is my adaptation of his routing jig. The dowels are a press fit into the holes so they can be positioned to protrude from both sides of the jig. Disregard the filled in slot on the plywood. False start!
The Martin shaped peg head fits this way.
Grip the side dowels and the peg head in your vise. Rout the slot with a plunge router and a collar.
Tap the dowels through to the other side.
Again clamp the dowels and peg head into your vise. And rout the other slot.
Produces balanced slots.
Remember to drill the side holes for the tuner shafts BEFORE you cut the slots.
Author:  Glenn_Aycock [ Wed Mar 25, 2015 8:17 pm ]
Great demo! Thanks for sharing.
Another variation which doesn't depend on the headstock shape:
You would have to lay out and drill holes the diameter of the slots at the end of each slot (another simple jig).
Use the holes on one side to align index pins of same diameter so that you can cut the other side. Then push the dowels to the opposite side, flip and repeat.
You can also add a slot to contour the top of the head and it should be symmetrical by design.
Author:  charliewood [ Mon Aug 10, 2015 9:47 pm ]
Thanks penndan,
thats exactly what I needed to see
cheers cw
